TRAM CLUB ROMANIA Comunitatea prietenilor mijloacelor de transport in comun
| Subiectul anterior :: Subiectul următor |
| Autor |
Data înscrierii: 25/Noi/2005 Ultima vizita: 10/Mai/2022 Mesaje: 1621 Locație: Cluj
Trimis: Vin 12 Mai 2006 14:10:32 Titlul subiectului: SKODA 22 TR |
22858 |
Skoda 22 TR
LUNGIME: 18070 mm
LĂȚIME: 2500 mm
ÎNĂLȚIME: 3365 mm
AXA A: directoare
AXA B: motoare
AXA C: motoare
PROPULSIE: tandem 2x 132 la 600 V și 2x 167 la 750 V
CAPACITATE: 41+140
ÎNĂLȚIMEA PODELEI: 345 mm
Un articol despre Skoda 22 TR. Citez:
©KODA 22 Tr TROLLEYBUS
©KODA 22 Tr trolleybus is a quite new upgraded three-axle, four-door trolleybus utilizing the component unification with ©KODA 21 Tr trolleybus.
The low-floor trolleybus has a floor clearance of 360 mm in the front vehicle section and in the rear
a floor clearance is 560 mm. Wide, double-section doors of width 1 360 mm allow swift, safe and comfortable boarding. On both sides of articulated joint there are located single-section doors of width 680 mm.
By means of push buttons, the passengers are able to control the individual doors independently at trolleybus stops both outside and inside the vehicle. A floor boarding height at the first door allows easy access for disabled persons or prams. If necessary a driver can further bring down the floor height by means of so called "kneeling" and the right vehicle side drops at stops by 60 mm.
Floor is covered with nonskid flooring allowing safe passenger circulation and easy vehicle cleaning.
Unobscured visibility to all passengers is provided by a large glazed area. Basic information during running can be done via an installed video-audible information system.
A driverŽs station meets the latest ergonomic requirements. Large windscreen, thin side pillars, side glazing and door glazing allow a good driverÂŽs vision.
The driverŽs seat is anatomically countoured and can be adjusted logitudinally and to the height. A steering wheel can be adjusted logitudinally and to the height as well. With two-pedal control and with a clear dash board arrangement, the driverÂŽs fatigue is substantially reduced.
Heated rear-view mirrors.
A safety of running is assured by an effective brake system consisting of:
Dual-circuit air brake
Electrodynamic recuperating brake
Parking brake
Semiautomatic station brake
Unique running properties under all grip conditions are ensured by two rear driving axles allowing the vehicle to run under a decreased grip condition where the vehicles with one driving axle already slip and are not able to continue in operation.
BASIC TECHNICAL SPECIFICATIONS
Continuous motor power output (kW)
at rated voltage of 600 Vss 2 x 132
at rated voltage of 750 Vss 2 x 167
Max. short-time motor power output (kW)
at rated voltage of 600 Vss 2 x 240
at rated voltage of 750 Vss 2 x 300
Length (mm) 18 070
Width (mm) 2 500
Height (mm) 3 365
Curb weight (kg) 18 000
Total weight (kg) 28 000
Number of seats 41
Total accommodating capacity (passwengers) 140
Top running speed (km/hr.) 70
Boarding edge height (mm) 345
Boarding edge height when kneeling (mm) 270
1. 22 TR
2. Partea ușilor. Se observă că are două "jumătăți" de ușă, de o parte și de alta a articulației.
| Descriere: |
| Mărime fișier: |
2.51 kb |
| Vizualizat: |
de 14129 ori |
| Descriere: |
| Mărime fișier: |
13.1 kb |
| Vizualizat: |
de 13380 ori |
| Sus |
Nu puteți crea un subiect nou în acest forum Nu puteți răspunde în subiectele acestui forum Nu puteți modifica mesajele proprii din acest forum Nu puteți șterge mesajele proprii din acest forum Nu puteți vota în chestionarele din acest forum Puteți atașa fișiere în acest forum Puteți descărca fișiere în acest forum
